Colorqube 9203 - error 099-394
  • ruimestre
    • Mar 2012
    • 36
    [Dead] Colorqube 9203 - error 099-394
    Hello
    Please Help my machine is giving an error 099-394.
    What is the Problem?????
    Thank you all in advance.
  • Lee2475
    • Oct 2014
    • 48
    Re: Colorqube 9203 - error 099-394
    Could be the power supply, you need to do itno dc123 and look at the pest fault codes, press and hold the # key, * key and the Stop key. Enter the passcode 1991. Touch the Enter button on the ui.
    99-394 Hard Check the PEST fault history, dC123 for power supply heater faults (ink melt plates, pre heater, drum heater).
    Install a new power supply unit,
    • ruimestre
      • Mar 2012
      • 36
      Thank you very much
      Spot on!!!!!
      • Lee2475
        • Oct 2014
        • 48
        Originally posted by ruimestre
        Thank you very much
        Spot on!!!!!
        Did you sort this ok?
        • ruimestre
          • Mar 2012
          • 36
          Yes changed the board with the power suply.!!!
          Thank you very much!
