xerox wc 5675 df motor making noise jam first copy
+ More Options
Posts
  • mdm
    • Jun 2009
    • 132
    Good day everyone I a real good one. We are working on a wc 5675 that the df is making a noise and jamming on the first copy.
    we replace df motor, df board and about to upgrade software. but I wanted to throw out to the master minds on this forum.
    Any help would be appreciated.
  • Iowatech
    Not a service manager
    • 3930
    Re: xerox wc 5675 df motor making noise jam first copy
    First of all, I am still kind of a noob for Xerox equipment, and as such this could possibly be the stupidest reply you get. I apologize if that is the case.
    Still, have you replaced any of the feed rollers in the doc feeder? It sounds a little like they are worn, and could be making the sound you hear. If time permits you might want to manually engage the sensor that detects documents in the feeder and listen to what happens when you try to make a copy or scan.
    • xyetti
      • Mar 2015
      • 6
      Is anything seized or dirty?
      • Exok
        • Jun 2011
        • 750
        Have you removed the covers and ran component control in service diagnostics to determine what exactly is making the noise? If its the main DF main motor and a new motor was no help then something must be seized in the drive system. Go through it and clean all bushings, bearings and pulleys. I know the exit rollers on these machines after time turn to goo. They look like black chewing gum on the shaft (just like the rubber inverter rollers tend to do). If that happened it could seize up the drive system.
        • big mike
          • Sep 2012
          • 155
          I agree. You have to separate the top half to get to the 'gooey' roller. I saw this problem on one of mine last week. The customer complained about noises, I replaced the feed rollers, a day later they called me back for the same problem. This time I heard it and realized what happened.
