Hello to all the always helpful people out there, this forum has been an invaluable resource to me for years. What I have is something that has been discussed before in other threads but I have tried everything suggested and still I get the error code 9-343. I have checked the silver patch on the belt and it is fine and I have also replaced the 2nd btr unit with a brand new one and still no change. I have a dc240 here as well and noticed that after the machine first powers up, it cycles the 2nd btr unit and after it checks all the trays it then cycles the IBT belt. Assuming the dc5000 operates in much the same manner, I bypassed the door switches and booted the machine only to find the IBT belt NEVER moved not even the tiniest bit and right away the error comes up. I am aware that code can mean or point to several causes and I am hoping to get some more insight into what else I can check. Thank you all in advance and I look forward to hearing back.
Paul
Paul
