Hi all. Does anyone know if the start button from the xerox m35 can be ordered separately? or does it fit from another machine?
xerox m35-start button
Re: xerox m35-start button
You can use one from a st or dc 460 / 470 / 480, Buttons are same with M35.
If you have not any machine, You can replace one from the button (? or *) from the same keyboard.
Start have 2 buttons
Good luck!!! -
I don't understand the last part,with the ? And * button. Can you be more explicit?Comment
Adica ia microintrerupatorul de la butonul steluta sau semnul intrebarii si muta-l in locul celui defect.
Nu vin microintrerupatoare separat trebuie comandata toata placa la aparatul asta.Comment
If you have not any machine, You can replace one from the button (? or *) .These buttons is not very useful, from the same keyboard.
Start have 2 buttonsComment
It's about green plastic button not microswitch push button.Comment
I agree with you, I write for a solution when there is problem (2) micro switch on pwb of the keyboard.
If there is problem with the green plastic button then must been order a new one.Comment
