Colorqube 9201 - CBC vs SBC USB ALTBOOT?
  • prismtech
    • May 2014
    • 199
    [Dead] Colorqube 9201 - CBC vs SBC USB ALTBOOT?
    Hey Guys!
    I killed my drives in my 9201. It's a CBC machine without a conversion to SBC.
    Can I reload the firmware on this guy via ALTBOOT USB (FORCED_UPGRADE) Method? Does the .dlm file from the Xerox support site for the CBC version hook me up?
    Thanks!
  • adriansto
    • 2392
    Re: Colorqube 9201 - CBC vs SBC USB ALTBOOT?
    What software version is on machine ?
    I have some old versions
    • prismtech
      • May 2014
      • 199
      Hey!
      The unit is a CBC 9201 now with no version on the drives.
      I figured out you have to hit 8 or 9 at the machine status light to get it to boot to altboot.
      How long does it usually sit at upgrading? It's been an hour now. I used the latest CBC 9201 firmware from the Xerox website.
      I did throw in a set of matching Seagate 80GB replacement drives... should i have wiped them first?
      Thanks!
      • prismtech
        • May 2014
        • 199
        Is it possible the usb port has been disabled using PWS?
        I tried the same stick in a 9301 with a correct firmware and it fired right up. The 9301 is a SBC of course...
        I have my old 9.2 laptop, just haven't connected it yet.
        • adriansto
          • 2392
          After 2 - 3 minutes the upgrade must begin.
          Try another usb stick.
          • prismtech
            • May 2014
            • 199
            Hey! Thanks for the help Adrian!
            Turns out these early non tag 6 machines only support USB 2.0 sticks, not USB 3.0. Even though we only tried Kingston sticks... no go with 3.0.
            Our 9300 series ColorQubes read 3.0 sticks just fine.
            Thanks!
            • prismtech
              • May 2014
              • 199
              P.S. For anyone else reading this thread in the future... The Xerox website firmware .DLM files reload the machine from a blank hard drive just fine. A non-Xerox over-sized blank hard drive at that.
