Phaser 8560 RAM error
  • Thom
    • Jul 2014
    • 22
    [Dead] Phaser 8560 RAM error
    I have an oddball Xerox (I usually don't work on Xerox boxes) error. It comes up with RAM ERROR every time I boot it. I have replaced RAM and the electronics module. I can't get it to reset. Am I missing something here? Shouldn't that reset when you get the new parts in or is there a separate procedure to reset it? Could the new RAM be blown from a bad electronics module? Any help keeping my hair from being pulled out anymore would be greatly appreciated!
    Tom
    Central Iowa
  • tasosGR
    • Jun 2014
    • 23
    Re: Phaser 8560 RAM error
    Tom
    Central Iowa
    You must to watch this video:
    Good luck!!!!!!!!!
    • Thom
      • Jul 2014
      • 22
      Good luck!!!!!!!!!
      Thanks! I replaced the electronics module, but problem persists. I'm assuming the old module blew both the old RAM stick and then the new one as I installed it, at least that's the assumption I working under. I've ordered another RAM stick to try. Thanks!
      Thom
      • mercadoven
        • May 2014
        • 22
        Tom
        Central Iowa
        Hi,
        where did you get the new memory you installed? did you get it through xerox? I had the same issue with a phaser 4150, Problem solved when I tried different memory brands until I found one that worked with the machine. If you have the old memory stick try to use the same brand and memory speed.
        hope this helps,
