dcc400 WONT BOOT
  • BILKO
    • Aug 2008
    • 11
    dcc400 WONT BOOT
    Hi I have a Xerox dcc400 which during boot up comes up with error, switch off/on.
    I suspect it may be a hard drive problem, can I replace the HDD with a seagate drive which I have at my office, or please advise.
    Bilko
  • TechMate
    • Mar 2008
    • 285
    Hi. Would you be more specific (ie. error code or stuck in which DOT). Re: the HDD, I think these are pre-loaded with the system software of the machine. I haven't really tried using one from a commercially available source- but there's no harm in trying
    • BILKO
      • Aug 2008
      • 11
      Hi Techmate
      It fails to boot on the 4th DOT , one time it did boot up but we only could use the scan function.
      Cheers
      Bilko
      • TechMate
        • Mar 2008
        • 285
        It can be an NVM corruption. Try to reset the ESS NVM or press <POWERSAVE, STOP & 4> simultaneously. If it still does not work, then replace the HDD
        • BILKO
          • Aug 2008
          • 11
          Hi
          Thanks for the info , that seemed to do the trick , what does it do , reinstall the firmware on the HDD?
          Bill Keir
          • TechMate
            • Mar 2008
            • 285
            Yes, it re-initializes the HDD. Cheers!
