Colorqube 9201 - Fault code 093-558
  • ruimestre
    • Mar 2012
    • 36
    [Dead] Colorqube 9201 - Fault code 093-558
    Hello
    My Luck it seems that has run out...
    One of my Colorqubes today stopped at a middle of a printing job (map with yellow background), and on the display said that it was heating\warming up.
    After a little while error 093-558, a couple of cycles and still the same information warming up and then error 093-558.
    It seems that is the reservoir (yellow color) and the umbilical.
    Does anyone has any other ideas...
    Thank you all in advance.
    Cheers
  • jhalfhide
    • Apr 2015
    • 451
    Re: Colorqube 9201 - Fault code 093-558
    93-558 I have as printhead 3 MAGENTA did not fill in the correct time. Check supply to print head. Possibly new umbilical and ink reservoir required.
    • jaamco
      • Jun 2012
      • 5
      procedure
      • ruimestre
        • Mar 2012
        • 36
        Thank you Very much.....!!!
        I inspected just as the subscription and came to a certain conclusion.
        I think that the problem is the umbilical cables they seem to be a bit weary.
        I have already change the ink reservoir and the machine ran for a hundred prints then became unstable
        always warming up and maintenance... Until came to a stop a gives the same error.
        Late this week I will get the two new umbilical and try to get them into place.
        Its Gona be my first time doing soo if someone could arrange a manual I would be thankful.
        Cheers
