WC5745 speed
  • jeanpaul
    • Mar 2009
    • 117
    [Misc] WC5745 speed
    Hi to all,
    After a force alboot on a xerox wc5745, the machine speed has turn to 33.
    In NVM Dc131, I try to change the speed to 45.
    At 03-012 = 33 I Change to 45 with write option but the machine is asking for a password.
    Does someone know this password?
    Thanks & Rgds
    JP
  • zuojin168
    • Sep 2012
    • 83
    Re: WC5745 speed
    Change the octagon 24 c08w chip can't change the speed?
    • Exok
      • Jun 2011
      • 750
      Re: WC5745 speed
      An AltBoot wouldn't have done that. It sounds more like your software module battery has dropped to less than 2.8v. Check that first before you proceed.
      • jeanpaul
        • Mar 2009
        • 117
        Re: WC5745 speed
        Yes the yellow battery is about 2.2V
        What can I do?
        Rgds
        JP
        • Exok
          • Jun 2011
          • 750
          Re: WC5745 speed
          Replace the software module. Part # 960K65035. Ensure the new module battery is above 2.8v
          Do not install a used module as the meter reading will convert to the amount on the used module.
          A new module will zero out your meter reading and this can not be changed.
          Ensure that dc131 03-005 & 03-018 are both set to 4.
          Set the machine speed: Enter dc131 03-012 (pw-check PM) for 5745 set this to "45"
          Your NVMs will be at factory default. If you have saved your NVMs in the past you can do an NVM restore. If not, at lease make sure you run all the registration adjustments dc604.
          • adriansto
            • 2387
            Re: WC5745 speed
            Change only the yellow battery from nvm module.
            Note the code from battery and ask for at the local electronic shop. Also you can find it on ebay.
            • ok58
              • Jan 2013
              • 4
              Re: WC5745 speed
              Please send me the password.Thank!
              • rrk1366
                • Aug 2015
                • 7
                Re: WC5745 speed
                I need this password too. please send to me
                tnx
                • Lijodamodaran
                  service manager
                  • Sep 2014
                  • 56
                  Re: WC5745 speed
                  sir could you please share that password with me......thank you
                  • bluebear
                    • Jul 2014
                    • 16
                    Re: WC5745 speed
                    Hi Please I have the same issue on 5765, please kindly send password please thank you.
                    • hassanabdalrahim
                      Re: WC5745 speed
                      i want the PWS NVM Save & Restore tool and how to load a new nvm to my copier
                      • chelsy11
                        • Apr 2016
                        • 7
                        Re: WC5745 speed
                        Originally posted by jeanpaul
                        Hi to all,
                        Thanks & Rgds
                        JP
                        nvm values can be change if you have a pws laptop, try to change the 03-003 change to 5, 03-005 change to 4 and 03-018 to 4 after that turn off and put again the usb with altboot
