WC5745 speed
  • chelsy11
    replied
    Re: WC5745 speed
    Originally posted by jeanpaul
    Hi to all,
    After a force alboot on a xerox wc5745, the machine speed has turn to 33.
    In NVM Dc131, I try to change the speed to 45.
    At 03-012 = 33 I Change to 45 with write option but the machine is asking for a password.
    Does someone know this password?
    Thanks & Rgds
    JP
    nvm values can be change if you have a pws laptop, try to change the 03-003 change to 5, 03-005 change to 4 and 03-018 to 4 after that turn off and put again the usb with altboot
  • hassanabdalrahim
    Guest replied
    Re: WC5745 speed
    i want the PWS NVM Save & Restore tool and how to load a new nvm to my copier
  • bluebear
    replied
    Re: WC5745 speed
    Hi Please I have the same issue on 5765, please kindly send password please thank you.
  • Lijodamodaran
    replied
    Re: WC5745 speed
    Originally posted by Exok
    Replace the software module. Part # 960K65035. Ensure the new module battery is above 2.8v
    Do not install a used module as the meter reading will convert to the amount on the used module.
    A new module will zero out your meter reading and this can not be changed.
    Ensure that dc131 03-005 & 03-018 are both set to 4.
    Set the machine speed: Enter dc131 03-012 (pw-check PM) for 5745 set this to "45"
    Your NVMs will be at factory default. If you have saved your NVMs in the past you can do an NVM restore. If not, at lease make sure you run all the registration adjustments dc604.
    sir could you please share that password with me......thank you
  • rrk1366
    replied
    Re: WC5745 speed
    I need this password too. please send to me
    tnx
  • ok58
    replied
    Re: WC5745 speed
    Please send me the password.Thank!
  • adriansto
    replied
    Re: WC5745 speed
    Change only the yellow battery from nvm module.
    Note the code from battery and ask for at the local electronic shop. Also you can find it on ebay.
  • Exok
    replied
    Re: WC5745 speed
  • jeanpaul
    replied
    Re: WC5745 speed
    An AltBoot wouldn't have done that. It sounds more like your software module battery has dropped to less than 2.8v. Check that first before you proceed.
    Yes the yellow battery is about 2.2V
    What can I do?
    Rgds
    JP
  • Exok
    replied
    Re: WC5745 speed
  • zuojin168
    replied
    Re: WC5745 speed
    Change the octagon 24 c08w chip can't change the speed?
  • jeanpaul
    started a topic [Misc] WC5745 speed
    WC5745 speed
    Hi to all,
    Thanks & Rgds
    JP
