Energy saver button blinking only
  • mrfuser
    • 1605
    Swapped out power supply and still get energy saver button blinking only. Black screen. Nothing else happens.
    any thoughts?
  • copydocinc
    • Mar 2015
    • 263
    Re: Energy saver button blinking only
    You didn't mention make and model, but I have seen the hard drive cause this on Samsung machine
    • mrfuser
      • 1605
      Re: Energy saver button blinking only workcentre 5638
      Sorry my bad, 5638
      • xcopytech
        • Aug 2006
        • 1792
        Replace software module.
        • copytech200X
          • 264
          pls chk dc power supply for 5vdc or 3.3vdc output ?if normal then remove hdd and reboot machine ,mc recover?if same problem pls chg ess board and after recover pls set energy saver to off .
          • mrfuser
            • 1605
            How to turn energy saver completely off?
            • copytech200X
              • 264
              at the moment i still searcing my old archieve for this model SM ..for countermeasure u can set low and sleep mode to max time.
              • jhalfhide
                • Apr 2015
                • 451
                NVM 616-002 is used to fully disable energy saver. It's cheaper than replacing the LVPS [emoji6]
                • Exok
                  • Jun 2011
                  • 750
                  If you can't get the machine to boot up you won't be able to change an NVM setting. It sounds like a LVPS problem but it could also be an electrical short someplace in the machine. If you suspect its a short try to disconnect all units one at a time till you find the one causing the problem.
