Xerox Nuvera 120 Not Seeing Multi Function Finisher
  • tpant
    • Apr 2014
    • 67
    [Misc] Xerox Nuvera 120 Not Seeing Multi Function Finisher
    Just setting up a new to me Nuvera 120. It it not seeing the finisher. Any suggestions are welcome.
    Tom
  • adriansto
    • 2392
    Re: Xerox Nuvera 120 Not Seeing Multi Function Finisher
    There is a mimic on the DocuSP screen upper right hand corner or a error code is displayed ?
    • tpant
      • Apr 2014
      • 67
      The "mimic" in top right corner only shows feeder and print engine.
      • adriansto
        • 2392
        The MMF communicate using CAN bus. Check the cables connections and software version.
        The printer cant see the mff at start up.
        • tpant
          • Apr 2014
          • 67
          The only cables going to finisher is a 4 or 5 pin power looking cable and a db9 cable. Should there be a ethernet cable going to finisher.
          • adriansto
            • 2392
            The serial cable perform the connection. Check again.
            As I said for this machine you need service manual ewspecially it is the production machine type not only copier / printer machine.
            • xtrain
              • Dec 2012
              • 233
              The low voltage power supply in the MMF finisher is known as a inherently defective part. and causes this problem.
