Re: Xerox Nuvera 120 Not Seeing Multi Function Finisher
The low voltage power supply in the MMF finisher is known as a inherently defective part. and causes this problem.
The serial cable perform the connection. Check again.
As I said for this machine you need service manual ewspecially it is the production machine type not only copier / printer machine.Leave a comment:
The only cables going to finisher is a 4 or 5 pin power looking cable and a db9 cable. Should there be a ethernet cable going to finisher.Leave a comment:
The MMF communicate using CAN bus. Check the cables connections and software version.
The printer cant see the mff at start up.Leave a comment:
There is a mimic on the DocuSP screen upper right hand corner or a error code is displayed ?Leave a comment:
Just setting up a new to me Nuvera 120. It it not seeing the finisher. Any suggestions are welcome.
TomTags: None
