xerox wc 7675 fault code 10-321
  • Mukasa
    • May 2015
    • 178
    Hi guys a you ok? my machine has refused to reset the fuser system error.
    I reseted NVM 744-530 to 744-352 all to '0' fualt not cleared.
    Changed fuser motor, IOT driver, and LVPS. still getting 10-321.
    Help me out please.
  • InterfaceP
    • Jun 2013
    • 488
    Re: xerox wc 7675 fault code 10-321
    This is a fuser nip sensor fail. Did you replace the fuser?
    • Mukasa
      • May 2015
      • 178
      Thanks for the reply, i have changed the all fuser sensor too but still no change.
      The machine gets ready to copy /print but when you send a comand to copy /print it starts to rotate to make a copy but the fuser motor fails to rotate at all even in the process of warming up.
      • yomba
        • Jul 2012
        • 37
        Check the fuser nip in service mode.
        dC330 [010-203]
        if that fails your next option would be the mc board
        • Mukasa
          • May 2015
          • 178
          dC330 [010-203]
          Thanks Guys ,i replaced the MC PWB and the fault cleared machine now ok.
