Workcentre 7425 yellow misregistration
  • 357
    • Aug 2025
    [CQ] Workcentre 7425 yellow misregistration
    Workcentre 7425 color misregistration. appears to be just yellow. 1 to 2 mm. went into registration, control, setup, cycle no help.
    and no apparent place to make manual adj. is there an adj. mode or are the sensors shot?
    Thanx
  • Mukasa
    • May 2015
    • 178
    Re: Workcentre 7425 yellow misregistration
    Thanx
    Hello my friend , i think what you need to do is remove the Fuser Unit, IBT assy then you excess the MOB sensors clean them very well.
    After all this enter diagnostic on the UI then run Reg-Con. when complete switch off and on.
