Docucolor 240
  • almerico
    • Oct 2012
    • 58
    [Dead] Docucolor 240
    Hello everyone, while updating the firmweare my docucolor 240 went wrong and since then no longer loads. The progress bar stops at the first and only DAFTgoes up and down. The DC240 will not start with no alternate boot.
    I mounted MCU PWB NVM (IOT), ESS PWB NVM (SYS2), EEPROM (SYS 1) HDD and a printer DocuColor 250. I did the procedure Machine ID / BILLING Date Setting putting in place Serial Number, Product Number and Billing Data . I initialized the partition in HDD and initialize the NVM with PWS Diagnostic mode and gave me error Controller, SYS-User and Sys-Sistem. How can I fix the problem? If you must install Firmweare again, can someone help me as it is not in my possession?
    What I need it is:
    ESS: 1.231.16
    IOT: 8.32.0
    ITT: 11.56.1
    ITT D: 12.3.2
    ADF: 11.8.0
    and that of the Finischer.
    Thanks and sorry for my English.
  • Flash
    • 378
    Re: Docucolor 240
    Try replacing the memory on the ESS board.
    • almerico
      • Oct 2012
      • 58
      Re: Docucolor 240
      which memory? RAM?
      • InterfaceP
        • Jun 2013
        • 488
        Re: Docucolor 240
        Yes
        • almerico
          • Oct 2012
          • 58
          Re: Docucolor 240
          RAM is Ok. Maybe it's the motherboard. I have not managed to figure out how to reset the firmware download
