Xerox 700 Digital Press - 10-342
  • puupsol
    • Mar 2015
    • 9
    [Error Code] Xerox 700 Digital Press - 10-342
    HI
    I have a xerox 700, giving error code 10-342. Its related to fuser, please advice how to get rid of error code.
  • Jake2o
    • Dec 2007
    • 325
    Re: Xerox 700 Digital Press - 10-342
    Hi your error code is reporting:-
    Decurler Cam Upper operation failure is detected
    it's possible that you had a jam or fault and the main body of the machine was turned off but not any accessories that are attached to the machine. Unplug / turn off all parts of the machine including high capacity feeder, booklet maker etc....
    Failing that open the paper path module of the machine and is there a spillage of toner around where the fuser sits and the decurler.
    It's nothing to do with the fuser that is error code 10-324 where you re-set an NVM to get the machine working again.
    • adriansto
      • 2388
      Decurler is not driven. One of the coupler is sticking on his shaft. Lubricate the shafts
      • Jake2o
        • Dec 2007
        • 325
        I've had this before on a 700.
        In my machines case the Y dev housing was spilling toner on to the OB side of the decurler unit and getting caught in the gears and cogs causing it bind and draw too much power.
        I hoovered out the cog & gears and it worked fine afterwards.
        Just needed new Dev housing in Y.
        • puupsol
          • Mar 2015
          • 9
          Thanks. coupler was not driven, Got it sorted. Thanks to others as well for the inputs.
          Look [ATTACH=CONFIG]29438[/ATTACH]
          • greg thomsen
            • Dec 2018
            • 5
            I have this same error code. I have followed the advice in this thread. I have vacuumed the toner, cleaned the gears, and oiled the shafts, and the decurler drive couplers in the inside back, I had to take apart the right side of the copier to reach them. I still have 10-342 fault code. What else could I try to get my 700 working again?
            • greg thomsen
              • Dec 2018
              • 5
              Do i have to replace the decurler drive? is it a motor of some sort?
                this has been a dead thread for over 4 years..
                please start a new thread of your own
                • Detonation
                  • Feb 2010
                  • 410
                  Hi Phil, is this forum policy? In most other technical forums moderators are pretty insistent on keeping solutions in one thread as much as possible, since it gives a more concentrated overview in search results. I really don't mind but just want to double-check.
                  • Caffeine
                    • 391
                    If your question relates directly to the topic of the original thread, I think it is much smarter to continue the old one. The fact that a thread is old is no reason to duplicate it, if it is directly thematically related. There is quite possibly good information already there in the old thread that will help out.
                    Never hijack a thread, of course, but if it is the same error/same topic, I say it makes way more sense to continue where those before left off.
                      Not policy... but has been guideline for as long as I've been here... Slimslob also notes to users like this also.
                      • InterfaceP
                        • Jun 2013
                        • 488
                        If you want to argue about old threads and weather or not they should be resumed or continued years later, maybe you should start your own thread in "General Discussion" otherwise offer help and stop thinking your a Mod.
                        Mr Thompson,
                        What is the meter on this unit? The decurler assembly is a HSFI part and needs to be replaced occasionally.
                        Do you have waste toner leakage on the decurler drive? This would cause a false reading on the sensor.
                        The error is an issue with the penetration motor on the decurler. Open the front door and cheat it open, remove the right cover to expose the decurler assembly. The code to operate in Diagnostics is 010-010, also test the motor rotation CC 010-011 (CW) and 010-012 (CCW).
                        I hope this helps
                        • greg thomsen
                          • Dec 2018
                          • 5
                          Interface: according to the meter, it is over 800,000. yes there was some toner spillage. cleaned it up, cleaned and lubricated the shafts and drivers. i can't seam to get into the diagnostic mode you spoke of. how do i do that?
