Docucolor 240
  • almerico
    • Oct 2012
    • 58
    [Dead] Docucolor 240
    Hi,
    can anyone tell me if the motherboard ESS PWB contains a reset, such as those of the PC?
    thanks
  • Daan
    • Mar 2013
    • 60
    Re: Docucolor 240
    it does, powered by a bios battery, if you cant find the switch just take out or disconnect the battery for 30s with the power disconnected and you will get a bios reset like in normal pc's.
    • copytech200X
      • 264
      Re: Docucolor 240
      can u access UI diagnostics?u can login UI service mode and initialize the IOT rather taken out NVM battery and it will cause trouble of machine malfunction.
      • almerico
        • Oct 2012
        • 58
        • copytech200X
          • 264
          Re: Docucolor 240
          press 3 + Stop + enery saver or power save NVM hard reset .
          • almerico
            • Oct 2012
            • 58
            Re: Docucolor 240
            no alternate boot works. I installed my MCU NVM, ESS NVM EEPROM, RAM and HDD on a docucolor 250 and gives me the error only 116 to 323, and it works all right. I think it's the firmware of the ESS PWB that I'm not from the printer.
