Xerox workcentre 4150
+ More Options
Posts
  • arriva1
    • Apr 2007
    • 66
    I have a Xerox workcentre 4150 that wont come to ready. It starts to boot up. Then the screen says preforming self test and thats all it does. No codes or anything. Any help would be greatly appreciated.
  • needlesgxe
    • Aug 2008
    • 30
    try clearing the memory on the main PWN.
    1. unplug power from the machine
    2. take the back cover off.
    3. unplug battery from the Main PWB (pin CN29)
    4.Warning: Do not short the battery. Use a Multimeter set to the VDC scale to Discharge the voltage on the pins at CN29 on the Main PWB for 30 second to 1 min.
    5. plug in battery
    6. place rear cover back
    7. plug and power up machine
    if that dosn't work, you may have to replace your hard drive
    • nekorequest
      • 10
      Mine did that at the beginning, too. It turned out that my problem was just because the drum cartridge was not fully set in properly, but I'm sure you've probably checked that already...
      • snook123
        Hi did you ever get to the bottom of this? i am having same problem so was hoping you have the solution.
        • snook123
          Hi just to let everyone know the suggestion from Needlesgxe was spot on did as he said and the printer is back to normal. Thank you very much!!!!
          Cheers
          • rar0411
            • 20
            Snook123 is no longer with our company and it's done it again, so i guess it's my turn to not short it!!! lol
            • rar0411
              • 20
              Just unplugged the battery for an hour and it seems fine now
              • needlesgxe
                • Aug 2008
                • 30
                This model machine does not do well with BAD POWER. If the customer has bad power in there building the problem will continue. Hook up power tester to outlet that there copier is hooked up to, preferably a line monitor. This will show and proof to the customer they have bad power. You can keep unplugging the battery and replacing the HDD or formate HDD but it is going to eventually take out the main board or the lvps.
