RE: Xerox wide format 6605
  • Mukasa
    • May 2015
    • 178
    [Error Code] RE: Xerox wide format 6605
    Hi Guys,
    The Xerox wideformat 6605 displays errror code 046-311 and error massage Internal power failure.
    I have measured the 24volt in every place following the service manual , leading me to the IOT pwb.
    I think the IOT is Locked up needs reset, but i don't know how to do it.
    Mukasa
  • adriansto
    • 2392
    Re: Xerox wide format 6605
    Check IIT ( scanner) optical sensors for dirt or debris.
    • Corder
      • Nov 2014
      • 105
      Originally posted by Mukasa
      Hi Guys,
      Mukasa
      Have you checked +24V LVPS monitor signal (24C)?
      • Mukasa
        • May 2015
        • 178
        Hello Corder,
        Yes i have checked the +24 LVPS monitor signal its available. The machine fuser Warms up but doesn't get ready to copy.It can scan fine.
        Hi Adriansto have also cleaned the IIT scanner sensors still displaying Error message' Internal System error'
        • Corder
          • Nov 2014
          • 105
          Hello Corder,
          I recommend you to dismantle the front baffle (PL 3.1 item 4 as for 6204) and try to reconnect each IIT sensor.
          • Mukasa
            • May 2015
            • 178
            Sorry ,i will dismanlte the IIT tomorrow and let you know the progress.
            Mukasa
            • Mukasa
              • May 2015
              • 178
              Mukasa
              Sorry again i have a 6605 not 6204.
              6605 have no baffle it has a Scanner Assembly PL 14.1
              Mukasa
              • Corder
                • Nov 2014
                • 105
                Mukasa
                Whatever. Get to IIT sensors and reconnect each.
                • rkdigitals
                  • Jun 2015
                  • 3
                  • Mukasa
                    • May 2015
                    • 178
                    Hi RK Digitals and fellow Engneers,
                    Thanks for your support, Yes the drum interlock switch unit assy was behaving funy repaired it still the fault was still there.
                    I found a loose conection on one of the two fuser PWB .
                    Now the machie is ok
                    Thanks God Bless you.
                    • a-kprinting
                      • Apr 2019
                      • 4
                      i had this same error it ended up being the main interlock switch for the door to image unit
                        this thread is 7 years dead and buried.
                        • Matoku
                          • 173
                          My Docuwide 3035 today error 046-311.
                          Solution. I just reconnect all the connector
                          On AC drive and LVPS. After reseat all and
                          Switch on the machine working fine. Thanks
