drum board
  • edpianix
    • 30
    [Error Code] drum board
    riso ez 220 got an error P96-569
    โ€‹Got this error after we replace the ink cartrage.
    we found out that this is drum board.
    we call the supplier of the machine, even the one who supply the ink and master.
    Do we have any solution for this.
    may God bless Us.
  • _SuabE_
    • Jan 2008
    • 108
    Re: drum board
    may God bless Us.
    Is this a colored drum? if this is a colored drum, dip switch is not set to the proper color, or the ink color is different from the setting of the dip switch
    sigpic
    Senior Technician Specialist
    A+; Network+
    Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
    Printer Handled: Canon, HP, Epson, Brother, Samsung
    Duplicators: Risograph, Duplo
    • edpianix
      • 30
      Re: drum board
      we been using this drum for quite some time, then got an error.
      can we repair it, or any replacement part code for this.
      where to buy this board. here in our place I been asking from my fellow technicians got same problems with.
      about 10 riso EZ 220 are put aside because of this drum board.
      could you help us.
      • 20gaugeO/U
        • 553
        Re: drum board
        Run service mode 117, then mode 890. It might not accept it if you are using generic ink. God luck
        • edpianix
          • 30
          Re: drum board
          thanks body i will try it.
          Can we buy Board for this if in case still have an error
