GR 3750 Check Paper feed area
+ More Options
Posts
  • cokwax
    • 50
    Faulty Power supply caused a fault on my system PCB. Replaced both. Now getting an error at startup "controllare area presa carta" which I guess means check paper feed are. No paper is jammed, Papers loaded to tray but machine cannot work. Tried test mode 97 in vain. Is this caused by the change of system PCB? Any advice?
  • filmplane
    • Nov 2014
    • 84
    Re: GR 3750 Check Paper feed area
    See this post here: it may be the safety bar switch:
    http://www.copytechnet.com/forums/di...tml#post553511
    • cokwax
      • 50
      Mine seems different issue. Safety bar switch is operating properly,Its switches click when pushed up and click again when released. Even its removal does not help.
