Ricoh DD 6650P with SC-509
  • T911
    • Jun 2007
    • 628
    Checked on the slider lift motor in the delivery area for debris but no luck, ran the motor in sp-090 and it was fine couldn't find the sensors in sp5 to test so i want to order the motor and limit sensor but i dont see it in the parts manual. If I'm missing something to look at help is much appreciated. See Attached Thanks
  • Iowatech
    Not a service manager
    • 3930
    Re: Ricoh DD 6650P with SC-509
    You might want to check on the Ricoh forum for this as Ricoh duplicator techs don't seem to show up here very often.
    I've only worked on Risos, so I'm not going to be much help. Sorry about that.
    • laitang
      • Nov 2012
      • 627
      Part manual: Check page 45, 46 : paper exit section 3
      • T911
        • Jun 2007
        • 628
        ok thanks
