Risograph problems
  • WayneBridges1988
    • Jun 2025
    Risograph problems
    I have recently purchased a Risograph TR1510, when I went to use it the other day I started to copy the master when suddenly the machine stopped working.
    The screen is now showing "E13" with a red light on the spanner icon.
    Can anyone help ressolve the problem?
    Many Thanks,
    Wayne
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    Cutter motor is locked up. To reset the code you simply pull out the drum and push it back in. However, if the cutter is still jammed up the code will just return.
    • WayneBridges1988
      I have just tried this, it went ok for ten seconds and then came up with error 13 again :-(
      What is the cutter motor - does that cut the master or something?
      Any other suggestions???
      Thanks,
      Wayne
      • Baphomet
        Copier Technician
        • Aug 2008
        • 293
        Yes, it cuts the master. It needs to be repaired or replaced.
        • WayneBridges1988
          Are they cheap to replace?
          Are there any engineer manuals that show how to repair them?
          Thanks for your help.
          Wayne
          • JustManuals
            • Jan 2006
            • 9838
            Riso - products new home -
            $11.77 and instant download.
            Paul@justmanuals.com
            • WayneBridges1988
              Hi Paul,
              Does this take Visa electron???
              • JustManuals
                • Jan 2006
                • 9838
                It should.
                • Elle
                  Formerly the Dispatcher
                  • Jan 2008
                  • 51
                  hehehe this should be interesting
                  • techathens
                    • 83
                    You may have to return the cutter to home (open) position manually once you remove the cutter. I have rarely had to replace the cutter units in the TR/CR lines for mechanical issue (usually replaced for blade problems - stamped metal, not drop forged), but it does happen. Let me know if you need one, I have some reconditioned cutter units from my days with RISO.
                    Salesout Pro
                    SalesoutPro@gmail.com
                    • joelsa12
                      • Nov 2008
                      • 260
                      E-13
                      There may be a small sliver of master material stuck in your cutter area. If you can find the cutter and take the front cover off the machine there is a small plastic philips scress on the cutter unit by the motor that you can use to put it back into home position. I hope that you did not pay a lot for the machine. It is not my favorite Riso ever built.
