printed shorter than original image
  • popurri
    • Jun 2025
    Hi
    I have riso rp3700 machine.
    When master is making, A long side of paper (420mm side of A3) is little shortened than original image.
    So to print accurate size, I have to increase the the length of the image by 102%.
    It's very annoying.
    Is there any simpler way?
    Re: printed shorter than original image
    Originally posted by popurri
    Hi
    So to print accurate size, I have to increase the the length of the image by 102%. It's very annoying.Is there any simpler way?
    Are you sure of:
    right size being sent to master?
    right size master?
    have you reset machine?
    had an error show?
    anything blocking size sensors?
    paper trays defined properly?
    right paper loaded?
    Phil B. " The Dentist "
    • 20gaugeO/U
      • 553
      The rubber write roller has shrunk a bit due to age/use. Adjust TM 287 (Master Making Speed Adj) to a slightly more positive (+) value.
