Ricoh DD 3334 duplicator master problems
  • tibbs
    • Aug 2008
    • 225
    Good day gentle people, i am not so good at duplicators. I have a customer with a ricoh DD 3334 duplicator with a master problem.
    1 The customer had the drum out of the machine for 3 weeks. so the dry is dry and has no ink on it.
    2 When making the master it only clamps the leading edge and the trailing edge drops inside the machine creating a paper jam.
    Question : can a dry drum cause the master not to attach properly ?
    Or is there something preventing the master making from attaching properly ?
    Any suggestions
    Regards
    • 37490
    Re: Ricoh DD 3334 duplicator master problems
    Any suggestions
    Regards
    It is the ink on the cloth screen that holds the rest of the master in place. Once it dries, that no longer happens.
    • GIUBOSS
      • 1435
      Any suggestions
      Regards
      to solve the problem try to gently clean the surface of the basket with a cloth soaked in water and degreaser or by spraying directly on it avoiding the ends. Also, you also need to spin the drum to get the ink to blend inside.
      • Mr2crazed
        • Jun 2014
        • 35
        Hopefully you have resolved your issue by now but if not, have you checked the press roller to make sure it's properly mounted? I've seen where the rear side of the press roller pops out of its retainer and no longer places enough pressure onto the drum causing the master not to stick.
