hello all! looking to see if someone can share the DC-646 service manual. We are not a Duplo dist, and are trying to help out a customer of ours that uses our Konicas.
I got the manual by contacting Duplo support directly—they sent me a PDF pretty fast after I gave them the machine's serial number. Worth a shot if the links are dead.
You can usually find the duprinter service manual by searching through older shared links on forums or checking with someone who has access from a previous technician role.
You can usually find the duprinter service manual by searching through older shared links on forums or checking with someone who has access from a previous technician role. I had luck with service manual website. Having a manual at hand is super helpful for setting the sensors and running diagnostics without guessing.
You can usually find the ************************************************** ********************* duprinter service manual[/URL] by searching through older shared links on forums or checking with someone who has access from a previous technician role. I had luck with service manual website. Having a manual at hand is super helpful for setting the sensors and running diagnostics without guessing.
The link you posted charges for what you can get from them. The one I posted last October does not.
In the future if you are going to post a link to a website that sells manuals be sure to specify that they can purchase a manual. Otherwise the post might get flagged as SPAM. And you could get permanently banned.
