Duplo DC-646 Service Manual Link?
  • Rewind!
    Somehow it works....
    • Jan 2019
    • 89
    hello all! looking to see if someone can share the DC-646 service manual. We are not a Duplo dist, and are trying to help out a customer of ours that uses our Konicas.
    Thank you for your time!
    JC
    • 37476
    Have you even tried to do a Bing search. I found a link to both the service manual and parts catalog on the first page of results. https://manualmachine.com/duplo/dc64...ervice-manual/
    • Rewind!
      • Jan 2019
      • 89
      Thank you for the link! I did search for them on edge, but did not try the google search engine. Thank you for your help!
      JC
        • 37476
        JC
        I avoid both Edge and Google search.
        • Mountacomp
          • Jun 2025
          • 3
          I got the manual by contacting Duplo support directly—they sent me a PDF pretty fast after I gave them the machine's serial number. Worth a shot if the links are dead.
          • Mountacomp
            • Jun 2025
            • 3
            You can usually find the duprinter service manual by searching through older shared links on forums or checking with someone who has access from a previous technician role.
            • Mountacomp
              • Jun 2025
              • 3
              You can usually find the duprinter service manual by searching through older shared links on forums or checking with someone who has access from a previous technician role. I had luck with service manual website. Having a manual at hand is super helpful for setting the sensors and running diagnostics without guessing.
                • 37476
                Originally posted by Mountacomp
                You can usually find the ************************************************** ********************* duprinter service manual[/URL] by searching through older shared links on forums or checking with someone who has access from a previous technician role. I had luck with service manual website. Having a manual at hand is super helpful for setting the sensors and running diagnostics without guessing.
                The link you posted charges for what you can get from them. The one I posted last October does not.
                In the future if you are going to post a link to a website that sells manuals be sure to specify that they can purchase a manual. Otherwise the post might get flagged as SPAM. And you could get permanently banned.
