Hello,
We just purchased an RP3700. It came with 3 drums two of which are working fine. BUT, we have a black drum which will not accept a new master. It currently does not have a master on it and when we try to make a new master for it we get the error code:
"A02-509 Master mis-feed. Rewind master roll and reset master in place."
Rewinding the master roll and resetting doesn't solve the problem as the same thing happens every time. We are able to make masters on the other two drums we have without any problems, so the error must be something to do with this drum in particular; the only differences I can see between the non-functioning drum and the two functioning ones is that the non-functioning drum has no master on it and is relatively dry (no tacky ink).
Thank you in advance for any help or suggestions,
Lucas
Lucas
