Accessing & repairing the PSU: Rex Rotary 1280 (Gestetner 5375/Nashua CP375) (2)
  • Eight-Days-a-Week
    • Oct 2022
    • 9
    • 23010
    Re: Accessing & repairing the PSU: Rex Rotary 1280 (Gestetner 5375/Nashua CP375) (2)
    It looks like something got corrected.
    Good luck. =^..^=
      • 37651
      How old is that? A Gestetner 5375 would be a C210 product code. The oldest manuals that I have are for the C211.
      I was able to find a service manual online. The odd numbered pages have 1 December 1993 printed on the upper right hand corner.
      Searching "Fuse" O see that there are 2 fuses, FU101 and FU102 on what I believe is the Main PCB mounted at the upper right corner under the front cover. That board also has 5 trimmers for making adjustments, one of them might be the one you need. There is also a circuit breaker on the incoming AC line.
      Good luck on a machine that old as parts may be hard to find.
      • Eight-Days-a-Week
        • Oct 2022
        • 9
        Many thanks slimslob.
        The date on my manual is April 1991.
        The 'Point-to-Point-Diagram' has a C210 on it.
        The Fualt-Chart says a dead machine is caused by (FU1) on its DC-Power-Supply PCB.
        The Main PCB that you mention, on this machine, I think is the control PCB, which is the largest PCB on the machine, at the front-top-right.
        None of the PCB's that I can see look like the 'DC-Power-Supply PCB' which has FU1.
        So I need to find that to start with.
        Which may under the Transport-Unit, as I said earlier, or possible slightly to the left of the drum, near the output section of the machine.
        I've got the outer plastic covers off, so now it looks like I have to start pulling off any internal cover etc, to see if it's behind them.
        The Noise filter is on the rear bottom left side, where the mains lead comes into the machine, so the PCB could be infront of that, but hidden inside the body of the machine, infront of the Paper Exit Section?
        None of the manual info that I have shows any detail of the 'DC-Power-Supply PCB' except...
        In the (exploded) parts section of the manual @
        16: Paper Exit Section: Page 40/41
        This shows the Power-Supply-Unit (item 7) + Fuse: 6.3 amp + Fuse: 15 amp.
        It's really not clear where this PSU is supposed to be, on the machine,
        it looks like it's at the output side (on the base) of the machine !?
        Many thanks.
        Anyone else have more info.
          • 37651
          It should be the board that the AC power leads connect to after the circuit breaker. On most older Gestetner models it is under the back cover, bottom corner at the paper feed table end. FU1 should be either a glass tube AGC 15 or an asbestos tube ABS 15.
          • Eight-Days-a-Week
            • Oct 2022
            • 9
            Thanks for you assitance:
            Looking at other A4 models of this period, the DC-Power-Supply PCB does appear to be on the rear of the machine, but this A3 models seems different, eg:
            Here's what I think so far...
            Please the the attached images.
            My 'Point-to-Point-Diagram' shows:
            The mains lead, goes to Main Switch, Circuit Breaker, Transformer, DC-Power-Supply PCB.
            The Fault-Chart says a dead machine is caused by (FU1) on its DC-Power-Supply PCB.
            The DC-Power-Supply-Unit is shown in the following 4 images, eg:
            image 1/2: item 7, including: Fuse 105: 6.3 amp + Fuse 107: 15 amp. (I think one of those is FU1)
            image 3: item 27, which appears to be under the fan.
            (the locaton seems to contradict item 7 ? Although the shape of the unit seems similar)
            image 4: item 55, this is the AC Drive PCB, which is fed from the other boards.
            Many thanks
              • 37651
              Item that the 15 amp fuse is the main fuse. If there is no power, then it would be the main fuse blown. Most like those fuses are not on the outside, too much electrical shock hazard.
              • Eight-Days-a-Week
                • Oct 2022
                • 9
                OK: I've located the PSU.
                It's a: Ricoh Power Supply Unit - A4: C210 8301
                So does anyone have any experience of repairing these PSU ?
                It seems that C210 is the machine version and
                8301 is the PSU version.
                8301 is used in various machines, (with different prefixes), so these powers supplies 'may' be similar to those used in other machines.
                I've yet to start checking this PSU, but I can see that various electrolytic capacitors seem to be leaking, which will be a common problem in equipment of this age.
                  • 37651
                  It it is more than the fuse,you might be out of luck. All it takes is 1 component of a switching power supply to fail and it will crowbar the entire PSU. With out on board schematics proper test equipment and knowledge on repairing power supplies it is near impossible to repair.
                    • 23010
                    Have you tried Hytec?:
                    Factory Authorized Circuit Board Repair by Hytec Dealer Services, Inc.
