GR1700 Master Trouble
  • mrfuser
    • 1627
    We have a GR1700 at a client that giving us a fit. Seems like the masters are at fault here. When we load a roll into the machine the green load and cut button does not work at all. We can sometimes get it to load a master, but usually it is off by about 2 inches, it actually doubles over in the clamp and sticks back out about 2 inches. Sometimes it won't load the master at all and just gets fed down before it reaches the cutter. Any ideas what is happening here?
    Kelly
    kelly@pcbmonline.com
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Check the master load sensor for blockage, failure, etc. Might be a scrap of master material blocking the sensor.
    • Kopyrtek
      Copier Psychologist
      • Jan 2007
      • 407
      Also check the load roller pulley to make sure it is turning.The set screw will back out and will not turn constantly.
