riso gr 3750 error T14
+ More Options
Posts
  • popo
    • Mar 2009
    • 30
    hi. when i start this riso gr 3750 this code appear please help me to resolve this probleme thanks
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    • popo
      • Mar 2009
      • 30
      PLEASE WHERE is situated this Clamp Safety SW can you give indication thanks
      • joelsa12
        • Nov 2008
        • 260
        Clamp error
        The thing on top of your drum that holds the master down is messed up. Or the dohicky that moves it back and forth in the back of the machine is fubared. good luck, but check and see if there is anything keeping the flap on top of the drum from moving back and forth freely
        • cobiray
          • Mar 2008
          • 1199
          Perhaps it's time to call a technician....
          • joelsa12
            • Nov 2008
            • 260
            My point exactly!
            That is what I was thinking, I was trying to use small words in my last post
            • popo
              • Mar 2009
              • 30
              riso gr 3750 T14
              thanks for your help i found it and i work in thanks again
              • selasie25
                Re: Clamp error
                Joelssa12, so what is the solution? Clear the memory? Or physically fix something? Need to print some docs and this T14-163 error code appear.
                • DAG COPIERS & COMPUTERS
                  • Oct 2010
                  • 860
                  Re: Clamp error
                  There are many posts on this topic with suggested and possible solutions on this forum. Just take your time and carefully go through the forum archives and threads connected with this particular problem and you will find more knowledge and wealth of information than you have even bargained for.
                  Good Luck.
