RISO GR3770 test 101: scanner crackling
  • ondemandprint
    • Sep 2016
    • 87
    Hello.
    Strange issue with test 101: Ink supply operation.
    For FB type, further, the image scanner shuttles between the Image Scanner home position sensor and the ADFshading sensor at a speed of 50%.) In fact machine loose both sensors. It moves scanner right until hits right scanner's frame (motor crackling with belt in this moment about 1 sec) then moves left until hits left scanner's frame (motor crackling with belt in this moment again).
    There are no problems in regular user mode. Scan is exact.
