Riso GR3770 Paper Elevator is moving very slow
  • Ghostwork
    • Aug 2023
    • 2
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: Riso GR3770 Paper Elevator is moving very slow
    It's been years since I've seen a GR. And I haven't seen that problem before.
    Do you get an error or jam code? Got Service Manual? Have you tried moving the elevator in test mode?
    Good luck.
    • Ghostwork
      • Aug 2023
      • 2
      Hej jermyth, thank you so much for your reply!
      I tried everything and ended up disassembeling the whole thing.
      All the mechanic wheels turn - it seems that they are really blocked by the motor, that somehow doesn't move as powerful as it used to.
      Do you guys have any advice where I could find a spare part like this?
      Thanks so much
      Martin
      • GIUBOSS
        • 1436
        Have you measured the input on it?
        • iampriyanka
          • Sep 2023
          • 1
          Delhi Call Girls
          Input is consistently welcome for us, so if it's not too much trouble, go ahead and reach us. Delhi Call Girls Your custom and satisfaction means quite a bit to us and assists us with being the best escort organization in by educating us regarding your experience and how we can work on our administration to you. On each female escort's page, there is a structure for you to compose a survey on them about our escort administration.
          • DWG
            • Mar 2017
            • 10
            Ghostwork,
            Did you ever figure this out? I'm troubleshooting it currently and have the same symptoms. I have switched out the Motor Unit with one from a donor machine, only to end up with the same results.
            It seems like the elevator tray is binding on its way up the teeth on the Elevator Rack, but his thing was printing just 24 hrs ago, so I'm a little stumped.
            • DWG
              • Mar 2017
              • 10
              Update:
              It was in fact a mechanical issue. The safety switch at the bottom of the Paper Feed Tray (the one that triggers Check Paper Area message) was bent, and contacting a machine screw - used to fasten the front elevator rack or plate as I think it's referred to in the manual - on it's way up.
