HELP! Riso RZ370 drum wont lock in or slide out of the machine
  • ianmck
    • Sep 2009
    • 40
    I had a paper jam and cleared the drum as per usual. When I went to slide the drum back in it met resistance and now won't go all the way in. However I can't slide it all the way out either. Can anyone please help me unstick this drum?
    • 37651
    Re: HELP! Riso RZ370 drum wont lock in or slide out of the machine
    Sounds like the pressure roller may have gotten released while you were inserting the drum.
    • VENRISO
      • Jul 2015
      • 72
      Hello, I hope this information helps you a little more, check the pressure spring and the pressure cam in the pics they can serve as a guide, if you need more help you can write to me on WhatsApp 584143726166 att, Andres Diaz RISO technical specialist
      • ianmck
        • Sep 2009
        • 40
        Thanka Andres. urns out it was user error. Somehow I set the drum in the holder wrong and it was catching. Once i managed to get the drum out and seat it correctly it was fine. it was you pointing to the pressure roller that made me look as to where it was catching by taing the front cover off, so even though it was n't the problem you suggested your advice helped and I am grateful for that.
