Riso master problem
  • bakaoni
    • Jun 2025
    Riso master problem
    i have a problem with the master....
    it says REWIND THE MASTER ROLL. I've already replace the master roll with the new one. but it still says the same thing.
    is there a SERVICE MODE....any ideas??
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    What model are you working on?Besides replacing the master roll,have you done anything else?
    • bakaoni
      RP215
      RP 215. when i pull out the sensor behind the U plate it work normally but i can't make new master because the knife wont cut the master.
      • Kopyrtek
        Copier Psychologist
        • Jan 2007
        • 407
        When you pull out the sensor behind the U plate it works?Try putting it in s/m and checking the sensor to see if it is working....or replace it with a new one.
