D02-532 Wrong type print cylinder installed
Re: D02-532 Wrong type print cylinder installed
I have the same problem on my EZ370E.
I have tried all the advice given but nothing the error remains .Comment
I am on a RISO SF9450 and this worked for me:
Error: D02-532
Wrong-type Ink print Drum Installed, Replace with Correct Type.
Solution:
1: Install a drum that is accepted by your printing machine.
2: When the printer is off, keep press and holding the left and right buttons, then switch the printer on. It should now show a "TEST MODE" splash-screen on the display,
6: Turn off the machine, remove the working drum and install the new drum.
7: When the printer is off, keep press and holding the left and right buttons, then switch the printer on. It should now show a "TEST MODE" splash-screen on the display,
6: Turn off the printer and turn on again.Comment
