Bitterroot Charles
  • Bitterroot Charles
    • Jul 2025
    Bitterroot Charles
    Riso GR 3770: Delivery Problem
    I get a paper jam message, everything stops and the delivery tapes just slowly drift 2 printed sheets of paper out that just manage to drop over the edge into the delivery tray (the print quality is perfect). Reset and it repeats with two more sheets that again slowly drift out instead of shooting out.
    Now, I do have another GR 3770 that gave out and can use for parts. I had a real expert repairman on the GR 3770, Sean, that worked for Anders in Missoula, Montana but he moved on and I can't locate him. So I guess my best bet is to try to repair it myself (especially as it is an hour travel time each way from the big city). If the suggestion is to replace some sensor, could you give me a tip on getting them out? Thanks.
    P.S. I kept playing with it, not knowing what I was doing, and somehow the paper started delivering properly (I ran 80 sheets to finish a run), but it is obviously reluctant about it for there is a noise like a gear might not mesh right or something knocking a bit like an old piece of farm machinery. It isn't terribly loud but I can't miss hearing it and knowing that no Riso I ever heard run before sounds like that. I'd appreciate any ideas for even though it runs, with that noise I can't imagine being able to run the 200 reams of paper I just finished accumulating for a hobby project, comb bound book I'm ready to start on. Thanks for any advise.
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    Although the copies come out, i would check the set screw on the transport bed.I know that they can come loose and cause jamming issues.Make sure the belts are turning as you run copies.
      Thanks. I have a printout of the ejection part of the manual but I couldn't find the set screw.
      It worked ok with several reams of paper but now it just prints two sheets and has a paper jam. Pull the paper out and it repeats and repeats, just like the original problem.
      If I can find the set screw I'll check that. Is it hard to replace the sensors?
      Appreciate your suggestion.--Charles.
      • Kopyrtek
        Copier Psychologist
        • Jan 2007
        • 407
        If you have the parts manual,look at item #8.The set screw goes into that pulley and drives it.If it backs out then you will lose drive to the belts.
          Thanks, You Were Right On, Fixed!
          You were right on! It was the set screw. My tired eyes couldn't find it but I got my young auto mechanic grandson to investigate and he found it and fixed it this evening in time for me to finish a booklet to pass out at church tomorrow on Sunday.
          I am so grateful to you. It would have cost a lot of money to get the repairman out from the city with a couple of hours travel time. Thanks you, Thanks You, THANK YOU!--Charles.
