Riso GR dried up drum
  • bigste
    • 62
    Hi everyone it's my first post so make allowances. I have several colour drums which have dried out to a certain degree. They print very patchy even after running several thousand prints. They had been idle for about 2 years in Spain where it's quite warm. Any ideas on best way to get them going.
  • mikadonovan
    • May 2008
    • 2931
    If you don't mind the mess, you can remove the drum body, take off the screen and clean inside and out with D-Ink (ink remover). I've gotta say though, if ALL drums including black are doing the same thing, you may have a problem with buildup on the pressure roller or a pressure adjustment may be out of specs.
    NEVER ASSUME ANYTHING
    • bigste
      • 62
      The problem is just the drums that have been idle a long time. I've read on here since posting this thread that simply washing the drum with diesel will clear it. They say that using a rag soaked in diesel on the outside of the drum should do it as inside is rarely dried up. Seems an easy solution so that will be my first try. I have several machines including gr3750 & 3770 and all are well used with 2 approaching 10 million. Don't think I've called a service technician out for over 5 years. They do give up now and then but I always get them going. I have a couple of machines I use for parts so it costs me nowt to repair them just time. Thanks for the advice, I'll let you know how I get on. Will need a new pressure roller soon if these are available as there are signs of wear in the middle which means I will need to put my hand in my pocket.
      • Joe Foe from Buffalo
        • 394
        If it was me...I wouldn't even even waist my time rebuilding or cleaning them with the pain in the butt they are to do. I have had to rebuild / clean these so i know. We can sell you ones that work for $250 a drum from a trade in we had and be done with the problem. Call 716-832-4950 ask for Ward.
        • bigste
          • 62
          Buying is not really an option. I live in a remote part of Spain and shipping is expensive from USA. If I did buy another drum it would have to be from europe but they are rare over here. Anyway I've gone ahead with a wet cloth soaked in diesel. Saturated the outside of the drum and left it overnight. Hey presto, after a ream of paper on both sides all is well.
          • zx81
            • May 2009
            • 25
            another option, especially if there is dried ink on the inside of the drum, is to stick a bit of diesel or kerosene in the end of an ink tube and stick in the machine. should disolve the hardened ink inside the drum (don;t put too much in though!) you'll need to run a fair few sheets through afterwards to soak up the excess diesel.
            • RRodgers
              • Jun 2009
              • 1947
              I usually just clean the screens with some Rubbing alcohol. That usually breaks up the ink enough to get things moving again.
              • skinthia
                Re: Riso GR dried up drum
                Hi there,
                Bigste, I'm responding to your first post with my first post!
                Totally new to the game -- just got a great deal on a Riso GR3770 with 4 color drums and trying to get acquainted with / set up my new machine. Since this machine was sitting around unused for 3 years before I snatched it up from its previous owners, I'm having the same problem with the dried up drums (at least I think that's the problem!) I get that I need to clean the screens, but I wonder if you, bigste, or anyone else on this forum, might be able to elaborate a bit on the cleaning and handling process?
                Do you keep the wet cloth wrapped around the drum overnight? Or do you just soak and then take the rag off so that the drum can DRY overnight?
                Can I use WD-40? Do you mix with water?
                Also, what is the proper way to handle the drum? I understand that it can't sit on its end (upright), but is it okay to rotate it every which way while I clean the screen?
                Should I actively (but gently) rub the screen, or just let the wet rag sit on top?
                I tried to find videos of people cleaning their drums, but I guess that was a bit of a stretch. I would really appreciate anyone taking the time out to give me a detailed breakdown of how this is done! I am just wanting to be really careful not to mess anything up while trying to clean.
                THANKS IN ADVANCE!
                • palomamolap
                  Originally posted by skinthia
                  Hi there,
                  THANKS IN ADVANCE!
                  I would love answers to these questions too! I wish I knew. Hopefully someone awesome would be able to help us out!
                  - Paloma Dawkins
                  • ddude
                    General Troublemaker
                    • 473
                    Easy to do- place the drum on the rails, remove any master that may be on the drum, so only the screen is exposed, then soak the screen with the solvent of your choice (everything from alcohol to diesel ), let the solvent-soaked rag sit on the drum for ten-twenty minutes, then insert drum and make a master-repeat as needed until the copies look awesome.
                    2000 mockingbirds = 2 kilomockingbirds
                    • ddude
                      • 473
                      SHAMELESS PLUG!!!
                      I do have new GR color drums, never inked, for sale, $275.00 each plus shipping from California- Discounts for multiple units available...
                      Still in sealed OEM packaging, with inking instructions.
                      ddigitaldude@hotmail.com
                      • sjuskadur
                        • Nov 2016
                        • 8
                        Awesome answer, super helpful!
                        I had some additional questions that I wanted to ask, any response is greatly appreciated (I realize this is an old thread but its still very helpful)
                        I recently got my hands on Riso EZ221 u with one black drum. So far I have not found extra drums online but I am searching.
                        because I have only one drum I figured I would just have to change the color of the drum for now.
                        Cleaning of the screen should effectively do the same thing as just switching color drums right?
                        I want to try and not blast through 600 pages and a master just to fade between the colors (spends a LOT of ink as well)
                        Also if anyone of you has extra drums for this model for sale, I am interested in picking up 1 - 3 drums
                        Thanks!
                        G
                        • mersault
                          • Feb 2014
                          • 11
                          • RRodgers
                            • Jun 2009
                            • 1947
                            Thanks!
                            G
                            it's easier and a lot cheaper just to get another drum I know it's hard to find one but changing the color out is expensive and I don't know if that model supports having a color in the black drum rather than black.
