RISO GR1700 Drum Problem (see image)
  • KevinWWFG
    • 18
    Hello
    So I have a RISO GR1700. I have 6 color drums and 1 black drum. The color drums work well and I don't really have any issues with them The black drum on the other hand seems to have developed an area that won't ink. I attached a picture where you can see the un-inked band that goes around the drum. I'm wondering if anyone has had this issue and if you can recommend a fix.
  • docu1
    gr1700 banding
    I would check the inking roller inside the drum. It is either damaged or has something stuck to it.
    • Joe Foe from Buffalo
      • 399
      1st I wouldn't keep the drum vertical very long. The ink will start to run to places you don't want. Next clean the screens and then the roller system in the drum mentioned.
      • RRodgers
        • Jun 2009
        • 1947
        I agree with both posts above. You are going to have to crack it open and see what's blocking the ink roller. (I'd be willing to bet it's a screw that came loose.)
        • KevinWWFG
          • 18
          thanks. i'll crack it open and give it a whirl.
