How to adjust feed table height on GR3750
  • WoodsleePrint
    • May 2010
    • 12
    How do I adjust the feed height table on a GR3750. Just installed new feed tires and stripper pad, played with all settings (angle & pressure) and I'm still getting feed probs with 20lb bond letter. I think the table is coming up to high. Setting on cardstock does help the problem, but not fix it entirely. Thanks!
  • RRodgers
    • Jun 2009
    • 1947
    There is a screw to the left of the feed tire
    • joelsa12
      • Nov 2008
      • 260
      Also if you are lucky enough to have a feed clutch that is the older one with the brown wire you could take this clutch apart and clean it. It comes apart with just some e clips. Dirt builds up in her and will cause the clutch to stick and cause paper jams
      • 20gaugeO/U
        • 555
        Feed table height it behind the plastic cover for the normal/cardstock lever. One silver screw on a metal slide plate. Feed table comes up, hits feed tires, feed tire frame hits sensor actuator.
