rp 3700 t01-537
  • alpererciyaz
    • Sep 2025
    [Error Code] rp 3700 t01-537
  • joelsa12
    • Nov 2008
    • 260
    it is not good there is an encoder sensor on the main motor. at high speed encoder is not keeping track. i would bet that you will be needing a new main motor. not too pricey but I would say at least $400 for a used one. had a few machine do this.
    from the manual to1-537 the drum failed to stop at position B (overrun)
    • alpererciyaz
      just thank u joelsa.as u said,main motor is the problem.
