I've found a few threads concerning feed problems with a GR3770, but I'm having a slightly different issue I think.
Basically, my machine was printing a run of 20 a3 sheets, it printed 11 successfully and then jammed on the 12th. It took the paper in a short way, stopped for a fraction of a second, took a little more in, then jammed and displayed an error message saying paper feed error.
I lowered the feed table, removed the paper, and tried again, only for it to happen again on the first sheet. I turned it off, left it, tried using card, but no success. It does the same every time.
I'm an absolute novice, only had the machine for a week and have no prior experience with Risographs. Do I need to get a service engineer out or is this something I can fix myself?
