Riso Rn-2030, system error: T25-026
  • Saladavis
    • Aug 2025
    [Error Code] Riso Rn-2030, system error: T25-026
    Hi All,
    I replaced the master roll and I have the following error anytime I power on :
    " !!System Error!!
    Turn Main Power SW OFF Then ON
    If Recovery has Failed, Call Services..."
    I tried to reset the Riso or starting the Test mode without success.
    I was thinking to replace the battery or to update the firmware.
    Thank in advance for any help.
    All regards.
    Sala
  • LA TECH
    • Sep 2010
    • 91
    Replace the battery
    • Saladavis
      Thank you for your Help.
      I will try to locate the battery and to replace it.
      Keep you informed.
      • Saladavis
        Hello again Manny (La tech),
        I unmount the panel control trying to locate the battery, there is a cylindric component with "black cup". It seems to be the lithium battery...but i am confused, i cant take off the cup very easy and there is a "BZ1" inscription near . may be it's the buzzer and not the battery.
        Any help or information to locate the battery are welcome.
        Thank you.
        All regards.
        Sala
        • Saladavis
          The battery is located at the back and not under the panel control, i'ts a CR 2450.
          I replaced it restart the Riso and it's working again "comme un charme"
          Thank you for your help.
          Sala
          • LA TECH
            • Sep 2010
            • 91
            Good job I was gonna tell it is in the main board in the back of the machine.
            • Saladavis
              Thank you again, you really helped The Literacy center in Falgstaff, Arizona.
              Sala
