error h101 for riso RZ
  • krtaoufik
    • Mar 2009
    • 9
    hello
    i want to know how illiminate the trouble code h101 for riso rz
    thanks
  • djdan73
    • Oct 2008
    • 64
    you need to input the value on the machine for the ink color the value is 1-black or 2-color
    you need to go into service mode the go to 890 and input what color of ink the drum is weather its black or color and that should get rid of your issue
    • pj4nh
      • Sep 2013
      • 64
      Re: error h101 for riso RZ
      is there a list of what all the errors mean and how to enter the appropriate code?
      • jermyth
        Riso dude
        • Mar 2011
        • 441
        Yes, get a manual. See Paul the manual guru.
        • Abimotek
          • Feb 2015
          • 59
          Double click on ur start key to go zero on display panel. Machine will Ready to printgood luck
          • onlygreatcopiers
            • May 2011
            • 41
            The machine either has "knock off" ink (generic) or "knock off" masters (generic) installed in the machine.
            Try installing Genuine Riso ink and masters and the problem should be solved.
            We are the largest supplier of USED RISO drums (over 400 in stock) and spare PARTS (most models) in the U.S.
            Let us know if we can help.
            Lindsey Interdonati
            President
            Only Great Copiers
            Wilmington, NC 28405
            • VENRISO
              • Jul 2015
              • 72
              I could be need to set the drums with the code number 890 test mode only team you can do with a genuine ink, the chip of the generic inks tend to unset the drum cards again
