GR3770 No Power
  • WoodsleePrint
    • May 2010
    • 12
    GR3770 No Power
    Just got a 3770 with an editing board and it won't power up at all. Any ideas? It was working before I picked it up, but we had a long cold drive home (4 hrs in the snow). Unit did not get wet, and has been indoors in dry heated room for a couple of days now. I don't have a service manual to know if there are fuses or whatnot to check first.
    Thanks for any help or suggestions.
    Russ
  • ddude
    General Troublemaker
    • 473
    Try leaving it unplugged for 30 minutes? I seem to remember some type of trip that would reset when unplugged for a while.
    2000 mockingbirds = 2 kilomockingbirds
    • WoodsleePrint
      • May 2010
      • 12
      Still no power...
      Tried unplugging it. Left it unplugged all day. Plugged it back in. Still notta!
      Removed power supply. No blown fuses. Checked wiring, no visable signs of shorts or wear marks. Could this be as simple as a bad power switch? Anybody ever had one go bad? Thx
      • joelsa12
        • Nov 2008
        • 260
        yes put a meter on it and test for continuity to see if it is bad. then follow the power with the meter while you have your meter out.
        • WoodsleePrint
          • May 2010
          • 12
          Ok so I am getting power to the power supply, just no further. I did notice that one capacitor has a nick out of its side. Could that do it? All fuses check out ok.
          If I'm looking at a replacement power supply, will one work from a gr3750? Thx
          • joelsa12
            • Nov 2008
            • 260
            i know that you said that all the fuses were good, but did you check the one on the bottom? there are a bank of fuses on the top, but there is also one fuse on the bottom of the power supply where the power comes in. i do not think that a 3750 power supply will work. i think that they are different. i believe i have one. if you are in need.
            • WoodsleePrint
              • May 2010
              • 12
              Unless there is a fuse on the underside of the board, I did check them all. They all were fine. I'm thinking that a mouse may have been in here. The nick in the capacitor casing looks like one tried to bite it.
              I have a spare 3750, so I'll take a look at the power supply there first. Thanks for your offer though. Can you PM me with a cost in case I do need one. Thx
              • WoodsleePrint
                • May 2010
                • 12
                Well I decided today to make this Riso a parts machine. I opened the top editing board cover this morning, and guess what I saw? How about a family of dead mice! They weren't there a few days ago. My guess is they played a good game of staying quiet while I was working on it earlier. Anyways, I decided to take the edit board cover off and swap it to my other 3770. When I got the top back cover off, I found their home. Needless to say, the wires are all chewed to **** on everything in their except for the cables that connect to the editing board. Thanks to those that offered assistance!
                • Huckleberry
                  • Dec 2011
                  • 8
                  Re: GR3770 No Power
                  My GR3770 has no power too. Powerswitch checked and even all breakers on the power board and also the one down under. All OK. So, I ask for a board to replace it. Offers welcome.
                  • jermyth
                    Riso dude
                    • Mar 2011
                    • 439
                    Re: GR3770 No Power
                    Did you check fuses on power supply board? Located behind front right cover.
                    Good luck.
                    • Iowatech
                      Not a service manager
                      • 3930
                      Re: GR3770 No Power
                      Check the power cord to make sure it is in good shape and securely plugged in on both sides. Also make sure the outlet the machine is plugged into is providing suitable voltage.
