When removing the master an error comes up and I have to remove the master manually. It looks like the master is sticking to the screen? The drum clamp opens, but only a few inches of the old master will have been peeled off and then there is always a tear in the master. What causes this?
I am also finding that when I create a new master, unless I apply some pressure on to either side of the master roll as it feeds on to the drum, there will be some wrinkling across the bottom left hand corner. Is this because of the rollers in the master making unit?
