riso gr3770 - pressure roller stuck...
  • gillje
    • 143
    I had a funny paper jam happen where the suction from the paper ejection belt ? was continuously running and single sheet got caught up on my drum, I ended up pulling the paper off, and taking the drum out... Problem is now I can't put the drum back in because the pressure roller is stuck in an elevated position. How do I return the pressure roller to the lower position so I can put my drum back in?
    Any help would be appreciated, thanks!
  • gillje
    • 143
    Re: riso gr3770 - pressure roller stuck...
    Oh, another search solved the prob -
    "Reach into the machine and pull the roller up as far as it will go without pulling it out of the cradle. Then, drop the roller. It should go to the right position. It could be a sign that something in the pressure system is malfunctioning, or it could be that the roller just got stuck up. If the problem persists, contact a tech."
    Worked like a charm, back to printing...
