Error Code T2
  • Montymaeker
    Error Code T2
    Oooops. I listed on previous post that the error message was a T12. It really is a T2 Paper Elevator Problem. Machine was in middle of run and upon replenishing paper supply, machine quit and went into T2 mode. I think I can rule out safety switches. Pressing "test print" a slight "purring" sound is heard for about a half second, but that is all. I have not unassembled the unit yet. Could it be a broken gear or perhaps elevator motor problem? thanks
  • xatrix
    • 27
    Re: Error Code T2
    If this is an older machine where the lift motor is in the back of the machine most likely you have a broken wire. From the elevator motor moving up and down the wires will flex and sometimes break internally. Make sure you meter them out. If its one of the newer machines where the motor and gearbox is in the front, check your wires and reseat connections. I've had a couple with bad motors and broken gears in that pack. Also make sure you blow out all the sensors.
    • JustManuals
      • Jan 2006
      • 9838
      Re: Error Code T2
      Do you think giving the model number might help?
      • Montymaeker
        Re: Error Code T2
        Sorry, it is a GR3770. The motor was defective and drawing excessive currant. As far a I can tell, the control boards were not damaged by the excessive currant pull.
        • RRodgers
          • Jun 2009
          • 1947
          Re: Error Code T2
          I could have told you it was from a GR.
          As far as a T2 goes, cut the tie wrap that is right under the elevator holding the cable down, that should fix your probs. (I use to do it all the time.
