riso broken gear rz 390 ui need parts manual
  • copiers89
    • Jun 2025
    [Misc] riso broken gear rz 390 ui need parts manual
    on back of thermal head  have  a gear with a screw holding these gear is  broken  i need part number and  somebody  tell me  if have this part
  • LennoxD
    • Sep 2011
    • 82
    Re: riso broken gear rz 390 ui need parts manual
    Parts number is 612-10010-008
    Description is GEAR; M1x20x6
      • 22999
      The error code is P-19-207. I just ran across it today. =^..^=
      • JVergin
        Service Tech / IT Rep
        • 216
        On the 390/590s, if you power-cycle the riso and hear a semi-loud BANG that isn't part of it's normal bang-clang noises, but it works just fine, and doesn't make the noise again until it's turned off and back on again, check this gear. It's most likely cracked and about to destroy itself in the near future.
        • Iowatech
          Not a service manager
          • 3930
          [ATTACH=CONFIG]25985[/ATTACH]
          Yikes, I haven't seen that yet. Any idea what happened there?
            • 22999
            No idea, but it's very common. We had 6 used Riso's in the office of which three were already broke, two already taken, and one left for me to scavenge. =^..^=
            • jermyth
              Riso dude
              • Mar 2011
              • 440
              The gear seems to be an engineered weak point to prevent damage to other parts in the master making unit. It's like a 80 cent part.
              • pc123321
                • Dec 2012
                • 103
                it is the machine design error
                only one screw one one side ,this gear turn back and forth to overcome the spring load at end via cam,
                i have this case one year ago , find part ,,,
                i found the part from used copy machine fuser konic c 352 with same dia and same teeth.but needed to drill two hole on gear i modify , used two screw one on each side with spring washer, you need a washer to adjust gear position
                • storm180
                  Anyone have instructions on the easiest way to replace that gear?
